How to ID a VT Senator?? Please help.
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by lil_oneblue, Sep 9, 2007.
  1. lil_oneblue
    lil_oneblue New Member
    HZ Sandman Ute, HZ GTS, VT Senator
    Hi,
    im about to buy a vt senator.
    i was wondering how to id it as being genuine? the id plate is that the only thing? as one of these would be easy to repoduce.
    is there any other way or any more signs etc so i know it is genuine?
    thankyou
    jason
  2. VT Berlina 07
    VT Berlina 07 15.37 @ 147 KPH
    Sydney, NSW
    96 EF2 Futura I6 Auto
    series 1 or 2? check that the engine output is what came with that model (ie 220kw series 1 and 250kw series 2) i dont know they are the outputs but you get what i mean:thumbsup:
  3. lil_oneblue
    yeh they also came with the 195. (like the one im getting).
    was kind of hoping that maybe i could decode the vin number or somthing to proove it.
    cheers
  4. minux
    minux Infidel Bear
    Check the build plates under the bonnet, do a revs check, call HSV customer service or Holden.
  5. VX_Wannabe
    VX_Wannabe New Member
    VX Exec
    also check on the rear wing usually on the LED light it should have Made In New Zealand also another way to check is somewhere on the front bar is should have the same thing
  6. Astranomical
    Astranomical Ecotec just kicked in yo
    Dee Why, NSW
    Hammerhead Eagle i-Thrust
    Ring up HSV and give them the VIN number.
  7. STEALTHY™
    STEALTHY™ So Wet For You!
    SA - The Roadworks State
    The HSV plate will be the decider. They aren't easy to get hold of, only on a stolen car, but then the numbers wouldn't match up.
    The VIN can also be checked by ringing HSV.
    What wheels does it have? Being a series one it will be a 5L (195). If its manual it will be a 5 speed, not a 6 speed. Not sure if theres a noticeable difference between the auto's
