how to identify a vt ss
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by pete d, Feb 21, 2016.
  1. Nut Kracker
    Nut Kracker Kamikraze
    Echuca Vic.
    VT SS 304ci (195i)
    Apparently, depending on the model of the vehicle, there are a few different codes for the computer sel susp (computer selected suspension).
    According to one GM forum web site. It means... "The GM build computer selected those parts to go into your car".
    I dunno...sounds feasible I suppose. But it's one explanation.
    http://forums.trailvoy.com/showthread.php?t=66146
  2. exec24
    exec24 Member
    SA
    VY Berlina Series 2
    comes up as 8BB = 1995 -2001 "SS PACK - A/CON - 8VK19"
    on my Vin Decoder,
    If you like PM me the VIN or Tag number and i'll see what comes up, also send me you email so i can it through via email
  3. Drewie
    Drewie Active Member
    East of Melbourne
    VX SS (Original owner).
    Hi 'exec' thanks for the above info...
    Here is the model number off my VX SS, which I have had from new, would be good to understand what the complete model number
    breaks down as. The model number on my build plate is VX8VK69-824-8BB not sure what the 824 represents either.
  4. SL/ENUT
    SL/ENUT The SL/E Fanatic!
    Burnie, Tasmania
    VB SL/E 5L and VC SL/E 3.3L
    8BB denotes SS pack
    824 denotes SS, V8 and 4 speed auto
  5. Drewie
    East of Melbourne
    Thanks for that info 'SL/E' appreciate it. Been searching the web but was unable to find any sites that decoded the Model Number, most only decoded
    the VIN.
  6. exec24
    exec24 Member
    SA
    VY Berlina Series 2
    I Need the VIN or Tag Number, which is the last 6 Numbers of the Vin starting at the L
    model number doesnt help me much
    Drewie likes this.
  7. gungazza
    gungazza Active Member
    west suburbs
    executive vt 5.0lt VZ CREWMAN
    can yo?u do mine please,vt 11/98 8uk69-124
    engine lb9
    trans m30
    axie gu4
    thanks mate
    body l403605
  8. SL/ENUT
    Burnie, Tasmania
    8VK69, denotes Executive. 124 also denotes that, further down.
    Motor is a Holden 5 litre 304
    Trans is a 4 speed automatic
    Axle is 3.08
    124 denotes Executive V8 4 speed auto.
  9. exec24
    exec24 Member
    SA
    VY Berlina Series 2
    ok, can you send me your email address
  10. Drewie
    East of Melbourne
    Some of these codes are a bit vague, on my VX SS the build plate says GU4 and like you say GU4 is a 3.08 ratio, but the sticker on my diff say 3.07 ratio even though the build plate says GU4. The tag on the diff bolt says LSD. Thanks every one for your help with these codes but some of them are a bit vague.
  11. SL/ENUT
    Burnie, Tasmania
    I believe the series I VT's the GU4 was 3.08. In series II onwards was changed to 3.07. The tag won't list if its LSD or anything, just the ratio.
    Drewie likes this.
  12. oska
    oska Active Member
    vx custom 600RR
    Drewie likes this.
  13. Drewie
    East of Melbourne
    Thanks Oska, good info.
  14. MYVESSV8
    MYVESSV8 Well-Known Member
    Brisbane/GoldCoast
    VE 6LT M6
    doesn't show v8 ute bugger
