brendan1414 said:How do i install a speed alert in VR
Old post still good info thx very much just for others I found circuit E hand brake on pin 6 ( yellow and matched unit wire) not pin 8 ( blue) ( pin 8 was oil light) on series 2 VS ute. ( maybe a typo online? )Dont need any better bcm or cluster just splice into wires already there.
I've got the diagram ...Ill find it.
Try this link..its to street commodores site http://forum.****************.com.au/showthread.php?t=8436153
A, circuit# 840, Orange/white stripe.
This goes to fuse # 1,or connector 3 terminal 2 and provides constant power for the unit
B, circuit# 39, Pink/black stripe.
Goes to fuse # 10 , or connector 1 terminal 2 and provides ignition switched 12V+
c, circuit# 1389, Green
Speed output from the speedo to the module.
(connector 2, position 9, behind the cluster)
And: (connector 2, position 8, behind the cluster)
Also shared with the Green wire at the cruise control module
D, circuit# 330, Light Green
Output from the module to the low fuel warning light on the dash.
The module does the prcessing & comparison of the resistance of the fuel sender & triggers the lo-fuel warning light when it beeps.
(connector 1, position 1, behind the cluster)
E, circuit# 209, Yellow
Goes to the yellow wire from the handbrake switch to beep if you drive off with the handbrake on.(connector 1, position 8, behind the cluster)
F, circuit# 151, Black/white stripe
Earth or connector 1 terminal 11
G, circuit# 30, Tan
This ties into the tan wire from the fuel sender that goes to the fuel gauge (connector 1, position 5, behind the cluster)
The diagram is from that site .....thanks for the use of it from the owner.
