How to install foglights on a vz executive
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Holden vz, Apr 27, 2013.
  1. Holden vz
    Holden vz New Member
    Ve Berlins
    Hey guys
    Got a sv6 body kit on my car but no fog lights
    thinking of buying a pair off eBay but just want to know if anyone has done this before and what I would need to install them
    if someone could help me out on this it would be greatly appreciated
  2. d.k.vmatt
    d.k.vmatt New Member
    Perth ,W.A
    '06 VZ SS
    being an exec your car wont have the wiring to run it, meaning you will have to wire it all yourself.
  3. Holden vz
    Ve Berlins
    Is it too complicated to do it my self or should I get someone to do it for me?
  4. loopie
    loopie Member
    sa
    vx
    do you have a basic skill and common sence, IF answered YES . you wont have a issue.. buy yourself a cheap test light to use checking for power //earths
    .. MOST kits come with every thing needed,, switch/ relay /wire/etc.. NOW the issue are they going too be true fog lights (yellow) if not there are clear lens there called driving lights,, IF that's the case check with your road authourity/police regarding use off them. Some states its illegal to use them in certain conditions. TRUE FOG lights are wired in too your low beam headlights, as too much light HIGH BEAM isn't want you want when driving in fog ... HENCE why there yellow... TAKE your time its pretty simple really ,, and your learning a new skill
  5. Torquative
    Torquative Sports Economy
    VE SV6 3.6L SIDI 6sp
    Just because its an executive doesnt mean it wont have wiring ... you'd be surprised the number that do.
    Quickest way to check is the fusebox under the bonnet - have a look at the empty relay spot "Fog Light". If you can see the little silver pins in that empty space then your in luck, if its just empty plastic holes then your out of luck.
    You can also poke around under the front bumper bar where the foggies would go and look for the plugs, they will be taped to other wiring looms and might be hard to spot.
    I'm not saying you WILL have it, I'm saying there is a chance you will have it. I have seen many VZ Execs with the wiring in place, equally I have seen many without.
    Fu Manchu likes this.
  6. Holden vz
    Ve Berlins
    nah don't have it so, I think ill buy some hids for it if there legal
  7. Torquative
    you lucked out, sorry bud :hmmm:
  8. Matt VZ
    Matt VZ New Member
    VZ Executive
    Are you able to buy a fog light bezel that will fit the executive front bumper?
  9. MYVESSV8
    MYVESSV8 Well-Known Member
    Brisbane/GoldCoast
    VE 6LT M6
  10. Torquative
    Short answer is no, trust me I tried.
    While the bezel pops out, there is nothing that fits it. I wasted much money on various bezels.
    I ended up buying some of the small round pencil fog lights from supercheap as they fitted in quite well, just cut the hole & stuck it in.
    This is the guide a mate did which gave me the idea http://forums.justcommodores.com.au...rmarket-driving-lights-into-standard-bar.html includes photos of his mates wagon.
  11. rowe147
    rowe147 New Member
    VZ executive
    hay mate i have done this , I have a vz exec and it took me a while to get it right i even swapped over the dull halogen light to xeneon's
    @Tourqative there are no stock wire looms on the VZ exec possibly on a Lumina/Berlina but not the exec
    what you will need for the install ...
    some common scenes
    a 30 amp pre made relay kit off ebay ($25)
    Good speaker wiring
    vz SS/CLUBBY pop out light switch off ebay ($40)
    lights/ or xeneons either way ($100)
    SS/SV6 light covers ($100)
    if you look up the Thread i made a post about how to wire up xeneons fog lights to a vz executive
    But you will need some understanding about relays to understand.
    Link > http://forums.justcommodores.com.au/vz-holden-commodore-2004-2006/208549-wiring-up-xeneon-fog-lights-genuine-fog-light-switch-via-relay-problems.html
    You could also go to a *GOOD* auto electrician to get them wired them but it will cost you at least $240 (not including all the other stuff you will need) in my opinion not worth it because its possible to do it yourself!
  12. rowe147
    rowe147 New Member
    VZ executive
    Sorry i forgot to answer this but xenon's are not legal in fog-lights simply because they are very bright and are only legal in a projector style lens
    i get high beamed by alot of angry drivers every time i use them but meeehhh havent been pulled over by police they even get drivers to move out the way :p
  13. Holden vz
    Ve Berlins
    haha ive done some research on installing them it seems simple I guess ill give it a go
  14. Holden vz
    Ve Berlins
    hey guys need your help again
    I got the fog lights working but now the low beam is stuffed I tapped the fogy's into the brown wire at the end of the loom were it connects to the headlights any suggestions
  15. Holden vz
    Ve Berlins
  16. gurtek7444
    gurtek7444 New Member
    Australia
    holden commodore VZ 2006
    hi i have fog light wiring and empty relay spot with silver pins in, so what will i have to do next???
    thanks
  17. Jake Thompson
    Jake Thompson New Member
    Vz commodore 3.6L V6
    So the foglight housings for a vz exec cant be replaced with housings from something like say a berlina, svz or lumina?
  18. stick3
    stick3 Active Member
    newcastle nsw
    vz sedan vs ute gsx1400
    no you need to get the whole bumper
  19. Fu Manchu
    Fu Manchu Well-Known Member
    WA.
    Slug powered VZ, a VE Calais & your mum.
    Most execs will have the wiring sitting there. Requires, foglights, suitable bumper (exec bumper can’t be retro fitted), Headlight switch with fog light switch, relay.
