How to interpret Battery Voltage reading vs. battery life?
Short answer; well to be honest you can’t.
Long answer; As
@chrisp stated in
this thread, the VF uses a type of lead-acid battery containing a calcium additive which are prone to suffering acid stratification. To solve such acid stratification, the charging system is designed to periodically ‘gas’ the battery to remix the acid. It does this by raising the battery voltage to a gassing point. This is why you will occasionally see battery voltages up to 15.5V
Further to the above, the BMC works with the ECU, Instrument cluster and Battery current sensor to control the Generator. The BCM thus manages the state of battery charge via a charging algorithm which has 6 charging modes (according to the workshop manual).
With each of these modes, different voltages are seen on the DIC but we simply don’t know which mode we are in at any time. As such, it’s impossible to accurately use the battery voltage you see within the vehicle DIC to determine battery or alternator health (in the old days seeing 15+ volts would have been a concern).
If you suspect a battery issues, and VF’s
must use the factory recommended sealed calcium battery (with vent tube) to work with the vehicle’s charging system, your best bet is to first take the battery out of the vehicle. Then, out of the vehicle, you can try charging the battery with one of the new smart chargers on the market that works with calcium batteries and has a recovery (sulphation) mode amongst other modes. Finally you can and should get a load test of the fully charged battery. That will give you a clear idea if the battery is ok or not.
Since you’ve had an issue with the battery going flat, I’d do a last sanity test by leaving the battery out of the car for 24 or 48 hours and periodically checking it’s voltage. Plot a Volt vrs time curve and you’d soon enough see if there is any issue.
If the battery seems to have recover after off car charging and tests OK, you can install it back into your vehicle. Many have stated on the VF forum that a locked car should be able to be parked for at least 6 weeks without start issues.
Should you still have issues with the battery going flat, you’d need to get the vehicle charge system checked, particularly the battery current sensor (serviceable = replicable part). This sensor is critical in measures amps going into and out of the battery and is uses this to estimate the battery Ah capacity and via other parameters determine which mode to charge with.
It’s not like the old days of an battery, an alternator and a volt gauge...
