NO HOON
Its a lot easier and safer to just make a small ramp out of pieces of scrap timber to drive up on. I just use some board about 35mm thick. Put the longest piece on the bottom and a bit shorter bit on top and then another shorter piece on top of that if you need to go higher. Your car cant fall down this way.
I used the gutter on my street back in the day, worked a treat. Totally agree with ramps, that's all I use now, customised to avoid bumper scrapes. Can't beat the peace of mind.
Yeap, Gutter oil changes are what it's all about.
Can you do an oil change when the car is on ramps? Won't The oil pool at the rear of the sump? Last time I did mine I reversed the rear wheels onto ramps with a chock half way up, the jacked the front up to be level.
Also, to make this thread more useful, last time I change my oil I notice some Orange stuff around the thread (Rubber? sealant?) and thought nothing of it. Now my plug looks a bit tired so I have a new one for the next change, but it is bare. Should I be putting something on the thread or using a washer to prevent leakage?
I don't use anything for an oil change, I have a really flat 10L drain tray, so I can nose it down my driveway which has a slight downward gradient, reach under and pop the plug.
For everything else though ramps and chocks. Otherwise I borrow a mates hoist. Personally I can't stand stands, lol. But in all seriousness it can limit the type of work you can do beyond a corner or an end, pretty much anything that involves bashing, pulling levering or rocking the car.
Yes, I believe you should have a copper washer on the Eco, well, mine does.
