How to know what year motor it is?
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by freefallin, Mar 22, 2013.
  1. freefallin
    freefallin Member
    UAE
    VY Berlina / VZ SS LS1
    So i might be taking my engine out this weekend for a tear down and i was wondering...how do you know what year the engine is?
    Reason i ask is the previous owner might have ruined the original engine (the one that came with the car) and put it another Ecotec, off an older model commodore.
    So basically, how can i know what year my Ecotec engine is?...or at least for which model commodore?
    I noticed there is like a part number on the side of the block. Something like "Series II Gm 24506029" does that tell me what year it is or are all Ecotecs the same numbers?
    Cheers!
  2. commodore665
    commodore665 expat Saffa
    New Zealand via Cape Town
    2005 SV6 & Alfa Romeo 156 V6
    More than likely to be the same year as the car I would think , the Series II GM 24506029 number would be an indication of this . In your case a series II VY
  3. freefallin
    freefallin Member
    UAE
    Over hear, the VXs and VYs V6 all came with S2 engines. I dont think S1 or any other ecotec was imported. So basically, from 1999 to 2004 all came with the same engine.
    I was wondering how i can know what year my engine was made? Or if it is a VXs Ecotec.
  4. freefallin
    freefallin Member
    UAE
  5. Kiddo
    Kiddo You're serious bro?!
    Mitsubishi Colt
    Safer to just assume the engine was build the same year as the chassis.
    Once essembled, the engine is just a lump of metal until its cranked and run for the first time.
  6. Demonica
    Demonica Mrs Wraith
    SE Qld
    VS clubsport
    24506029 is the casting number not the engine number
  7. Clutchy
    Clutchy New Member
    Wild west of Melb
    vz wagon
    Find the engine number and see if it matches the plate on the car.
  8. 88GreenVN
    88GreenVN Next Exit Left
    Surprise, Arizona
    Dodge Ram Van 1500 5.2 V8
    A VY engine would probably be between the following numbers:
    2002 - VA259837
    2004 - VA459286
  9. freefallin
    freefallin Member
    UAE
    Looked everywhere for the engine number but couldnt find it. The # above is all i could find! PLUS just the number 6. Its under GM.
    Any pointers as to where this engine number is!
    Much thanks!
  10. freefallin
    freefallin Member
    UAE
  11. freefallin
    freefallin Member
    UAE
    Ok this is what i just found: VB099729
    Search on google but couldnt come up with anything
  12. ashbox
    ashbox back in black
    The Car
    something black
    Shouldn't the engine number be on your rego papers?
  13. freefallin
    freefallin Member
    UAE
    Nope, only the VIN...unfortunately.
