how to make a vs start better
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by andyman, May 10, 2007.
  1. andyman
    andyman The Only 6sp VZ Wagon
    Orange, NSW
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    well as the tittle says if the car has been sitting around for a while like say 6 hours or more, or first start of the day etc, it takes approx twice as long to start as it does normally, personally i find it embarrasing it takes that long, or is something i will have to live with, from the age of the car,
    im thinking it may be fuel pressure related, but if i turn the ignition on like 10 times for the pump to prime it only makes a slight difference,
    so any ideas, all filters etc are new
  2. Thomas1
    Thomas1 New Member
    Melbourne, VIC
    VS L67 Statesman
    Mine does the same thing. Once its warm it starts right up, or I go to start it after its only been off for a few hours it will start right up.....I've learned to live with it (but I wouldn't mind knowing what causes it:p )
  3. azkwazere
    azkwazere Ahhh Yes, Ahhh Yes....
    .....SE Burbs
    VP 5-SPD / 24-SPD Racer Hybrid
    cant be the age... my car never has an issue with starting, ever... and its a VN, 1.5secs starts always.... wanna make mine faster though...i want instant start on turn....
    anyone know how ot imporve ignition itmes?
    aZk.
  4. ephect
    ephect Donating Member
    VS Acclaim V6
    oil pressure switch :)
    u've meantioned that priming the fuel rail makes no difference, so u can rule out ur fuel pressure regulator.. the fuel pump is wired thru the oil pressure switch, its about $20 from holden or $23 from repco, go genuine as my repco one failed to propperly fix it the first time round for me anyway.
    cheap and simple, check and swap a few relays around and jus to see if that makes a difference..
