[NSW] How to make your own Fuel injection cleaner
Status
Not open for further replies.
monaromadness
Castle Hill NSW
VX Commodore
Hi,
Bought some Liqui Moly fuel injection cleaner for my VX Ecotec V6, today & its expensive stuff. I have only ever used the Nulon one before but I have found that it does generally seem to work in that when I put it in the fuel I definitely get better fuel economy. I've done it many times before, works every time but it doesn't last so it actually works out more expensive.
Thought I'd try Liqui Moly to see if its any better than the Nulon one, its about twice the price.
The thought occurred to me that you might be able to make your own, the can says it contains Naphthalene petroleum & Naptha.
Someone told me that that is whats in Shellite & mothballs, is that true.
DOES ANYONE KNOW WHATS IN THIS STUFF? can you make it yourself?
Will using this stuff in a Ecotec V6 damage the motor?
Appreciate any comments
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
From the msds for liqimoli injector cleaner
And from the fuel system cleaner and conditioner
Skylarking
123
Downunder
Commodore Motorsport Edition
A soufflé has just three ingredients, butter, eggs and cream of tartar but it’s hard to make well. Simply mixing these three ingredients will not yield what you hope unless you have a detailed recipe and actually know how to cook well.
If someone has a detailed list of ingredients and a recipe to make quality injector cleaner, which a MSDS can never be as that is not it’s purpose, the little you think you may save could cost you 100 times more in engine repairs.
It’s usually much much simpler to just buy a few bottles of injector cleaner when it’s on sale at an auto store.
Voodoo_SV6
58
MY12.5 E3 R8 Manual+MY16 VFII SV6+MY11 VE S2 SV6
You can often buy these in trade size and they work out resonably cheap, but there is the upfront cost. Then you need to dispense them into usable sized bottles that fit in your fuel filler. I just wait till normal sized retail bottles, are 50% or more off and buy multiple units.
Immortality
Staff member
Sth Auck, NZ
Get a degree in petrochemical engineering...
gossie
Gold Coast.
VE International 3.6L
I’ve never bothered with all the injection cars I’ve had since the ‘80s.
I’ve given them a couple of tanks of 98 octane fuel once or twice a year and all seems good.
_R_J_K_
Zenki S14
How often are you using a bottle? It's not something you need to use constantly, it's like a service item.
Outside of that just run a few tanks of 98 through.
Skylarking
123
Downunder
The other thing for the OP to consider when using injector cleaner is that some manufacturer’s, Valvoline being the last I bought, state not to use more than 5 does between oil changes :eek: Presumably this is because the chemicals used by Valvoline are introduced into the sump via blow by gasses and may kill the protective properties of your oil, so you have ben warned o_O
The thing is, if you need to often dose with injector cleaner just to get good fuel consumption, the issue may be poor quality fuel rather than clogged injectors. Poor quality fuel is best addressed by changing your supplier of even better still by using 98 premium (as it’s more tightly regulated than the 91 which can contain all sorts of rubbish additives from what the regulators told me over the phone some time back).
1985VK
Australia
VK SL
Hi,
Shellite is not a bad guess and a worthy ingredient. What does it smell like? If it smells like you know what then it probably is.
1985VK
Australia
VK SL
It is easier to just look up the CAS number. The first ingredient is the give away. The rest are just fractions from the cut of xylene.
Status
