How to not set off the air bag light?
Miss-E
VTCOM6
VT Commodore
How do you remove the instrument cluster without setting off the air bag fault light?
Mines set off at the moment and i hate it. But my instrument cluster is probably coming out again to change the needles to red.
beeks
Banned
N.S.W
XR6 5sp MKII + DR 600S
Should'nt be an issue,if you know what you are doing.You'll most likely have to pay Holden to reset it for you,or your local auto electrician.
Miss-E
VTCOM6
VT Commodore
yeah im getting the air bag fault light reset by holden. But I probably have to take the instrument cluster off again in a couple of weeks to change my needles to red and make them light up green or pink. So any advice on how to take it out without resetting the air bag light again? Cause I dont know what I am doing :(
accentstencil
69
Eschol Park, Sydney
WH II Caprice, 5.7 2018 Equinox LTZ V
I can only suggest that you disconnect the negative battery teminal, which you should do when working on electrics.
daron
wizfiz
adelaide
VE SSV
removing cluster shouldnt set off light i have had mine out a few times
when you remove something dont turn ign on and youll be fine
if it lights up holdens will/can reset for 40 bux and if ya ask nice 20 bux
