How to put lowered coils in front!!!!!!
t-rob
woonona
forums.justcommodores.com.au
VR
just wondering how to remove the old springs on my VR and put the new ones in..
i attempted to have a go but the top bolt on the strut in the engine bay just would not come undone :bang:
do i have to undo everything connected to the strut and pull the whole suspention setup out to change the coil?
pictures would help greatly :)
cheers
Brett_jjj
Tamworth NSW
vs commodore
Just remove the strut from the vehicle,fit spring compressors to the spring and tighten them just enough to take the load off the top nut, and then undo the top nut, and then remove the spring.Spring compressors can be bought cheaply at places like supercheap etc.It can be dangerous to try to remove them without the use of spring compressors. .
airforceone
vx calais superc6
get a big #### off bit of steel piping and slot it over the wrench for extra leverage if everythin else u need to do is done and the nuts stuck, spray it with wd40 too
djvass
1996 VS BT1 SS 5ltr original
a rattle gun will do the trick. i had he same problem with one of mine just took it to bob jane asked them nicely if i could use the rattle gun for a sec and bob's your uncle came off straight away. I have done a few spring changes now and i alway loosen the top bolt just a little before i touch anything and i havent had a drama since. Others may not do the same or think that is right but that is just may little trick.
justbad4you
IF YOR NOT A HOLDEN
MELBOURNE S/E BAYSIDE
97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
Ask krisp he knows it all???? Or so he thinks
