how to re set ecu?
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by rat64eh, Aug 23, 2012.
  1. rat64eh
    rat64eh New Member
    sydney
    WL stato international
    hi all, just picked up a WL gen4 6L stato international.
    just wondering if there is a process for disconnecting the battery and re setting the ecu?
    have new plugs, leads and 4x oxy sensors to replace.
    thanks phil
  2. Munz
    Munz Right Foot Action
    Brisbane NTH
    VZ Calais LS1 / VL RB30e daily
    is the engine light on?
  3. rat64eh
    rat64eh New Member
    sydney
    it was yesterday, not this morning. i had the battery off for 2hrs, and on the drive home the gearbox (auto) shifts were thumping into each gear.
    i have a broken ht wire to replace.
    cheers phil
  4. rat64eh
    rat64eh New Member
    sydney
    replaced all the HT leads, started the car deffinatly runs better now,
    but now the engine light is on and the check power train warning is on the dash?
    should i dissconect the battery for a few hours?
    cheers phil
  5. Munz
    Brisbane NTH
    you could try - put the ignition to the ON position (do not start the car) and pull the ecu fuse for 30 sec
    if engine light remains then you will need a tech2 (holden) or tuner to pull codes
  6. rat64eh
    rat64eh New Member
    sydney
    i left the battery disconnected overnight. this morning, all good, no engine light, no power train warning and the auto's
    shifting as per normal again.
    now for new o2's iridium plugs and coil's
    cheers phil
