how to removal the material underlay stuck to the floor
peter1
peter1
vr series 2
i have remove the center console, front and rear seats as well as carpet and all under lay. i have removed all the floor bung to release all the water i had to remove some of the material glued to the floor to access the bungs. Found alot of moisture under edge of the material. Does any know how to remove the rest of this material from the floor and the rubber stuff from floor of the boot.
Vee-ard
QuickVR95II 2010 Survivor
Bayswater, WA.
Foam Tuned VR 5.0l Ute
The stuff under the underlay is bitumen. I think you'll just have to scrape it out.
2DIE
ONEDOLLAHOLLA
South Aus
www.torn.com
97 Acclaim
Id try something to soften it first, maybe some orange cleaner or.... anything that will soften tar, I cant speak from experience but once its broken down use a paint scraper.
I had to remove some from the boot of a car years ago, tried a wire wheel and it got pretty messy.
justbad4you
IF YOR NOT A HOLDEN
MELBOURNE S/E BAYSIDE
97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
The best way to get the bitumen coating off is use a hot air gun and paint scraper. Heat up the coating slowly and scrap it off. It will take time
OR Before you heat up the bitumen look around for splits & cracks in it also form under the car push out the rubber plugs which will help lift up the bitumen.
Chip up as much as you can first before you start heating it coz i will get messy.
If heating doesnt work
Other way is to melt it with deisel, deisel is safer as it has a much higher flash point so it will be safe to weld around after. Just were gloves & protective clothing when you use it and wash yourself very well after if you leave it on your skin it will take your skin off.
Also another way I have used is to get a wire wheel in a drill and it will oblitorate it off the metal, just make sure you wear safety glasses when you do it, also it works better on bitumen that hasent been heated or had a solvent on.
peter1
peter1
vr series 2
Hi thank you for all the replies hope this helps others as well
justbad4you
IF YOR NOT A HOLDEN
no worries at all................................cheeeers
VT-565
QLD
VT
I saw someone break it out with dry ice. throw it in (with gloves on of course) and it basically chills it, then tap it and shatter it out.
I previously used the hot air gun and scraper method.
Very thorough, but its a fairly slow job if its thick and its a pain in the arse.
Try the dry ice and let us know.
justbad4you
IF YOR NOT A HOLDEN
dry ice costs lol ya sisters hair dryer is free lol .......
vk.jonno
south east
Vk commodore, hq one tonner, hj ute,
we just layed some stuff on our 1tonner, its like tar, bitumen and like led i think haha.
we put it on with a heat gun.. so im guessing heat it up and pull it off?
