how to remove a thermostat from a super charged v6
Discussion in 'V6 Development And Modification' started by pjdm1980, Feb 25, 2009.
  1. pjdm1980
    pjdm1980 Shut up Jr I'm thinkin!
    Geelong, Victoria
    E1 GTS BUILD NO# 007, GQ Patrol.
    How do you remove a thermostat from a 1999 supercharged v6 statesman i think i have to take the super charger off becuase there is no way to get to the thermostat housing (IT'S AT THE BACK OFF THE INTAKE MANIFOLD) and the inlet pipe(GOES STRAIGHT OVER THE THERMOSTAT HOUSING) from the throttle body has three bolts i have two off but there is one at the bottom and it's right against the fire wall???????
    HHHHHHHHHHHEEEEEEEEEELLLLLLLLLLLPPPPPPPPPPPP!!!!!!!!!!!!!!!
    I'm stumped!:bang:
  2. Zuicider
    Zuicider Banned
    Stonedville
    Set of thongs
    its made to come off without removing the throttle body and manifold
  3. pjdm1980
    Geelong, Victoria
    i can't even see it unless i take off the throttle body (which i just did) now i can see one side of it?
    And one bolt sits directly under the intake pipe!
  4. chargedvx6
    chargedvx6 Active Member
    VY SII HBD Calais L67
    If you remove the boost bypass valve ( the round black plastic thing with a steel arm coming from it) that will help with access. 2 x 10mm bolts and remember the vacuum hose config.
    The super 6 engine has 3 bleed points and is a bitch if it's not bled properly. Because the thermostat bleed point is the highest point in the coolant system it will be the last one to retain air during the bleeding process.
  5. vsl67
    vsl67 Member
    VS l67 statesman
    hey have you double posted this? Go and have a look at your other post
