Sorry to double post,
Had a go at this myself, Dissassembly was going smooth until i got to the vent cover trying to remove it (slowly) and the clip happens to snap..no biggie i can fix this with industrial strength super glue ( I couldn't) and so i continue and everything goes smoothly. Re-assembly was fantastic all i had to do was put the door lock back on...but it wont go on... the lock case was fine the rod-thing? wouldn't go in properly so i spent hours trying to fix it all to no avail, so now my car has no door lock. Thankfully it still functions properly, i can still lock and unlock the car, however it looks like the rod that goes into the button/case is slightly bent and is the cause of all this trouble. Am I able to replace it??? To make things soooo much better I happened to drop my precision screwdriver, it happened to fall into the lock case, right between the hole and fall somewhere into the door card. So i will have to spend another day taking it all apart and fixing it again -_- /end rant
EDIT: FIXED IT! WOOOOOOOOOOOOOOOOO!
