HOW to remove front right guard from vt
ozzy_boy
lilydale
vt berlina 99
do i need to remove side skirt any suggestions PLZ:hmmm:
pjdm1980
Shut up Jr I'm thinkin!
Geelong, Victoria
E1 GTS BUILD NO# 007, GQ Patrol.
I'm not a 100% sure but I'd say you'd need to remove the bumper, head light and there woul be bolts under the bumper, unbeaten the door and the guard, on top of the guard where it meets the bonnet.
Maybe check out the how to section if there isn't a guide there then maybe you could make one?
jazza15
Jarryd
Eltham North, VIC
1999 VT II S
yeah probably easiest to fully remove, rather than partially remove (on the right side) the bumper.
I couldn't work out how to fully get off the side skirt, but removed most of the screws so I could pull it back to get to the guard bolts/screws.
You will need the right sized flat head screw driver to remove the torx screws holding in the bonnet strut to the top of the guard in the engine bay, support the bonnet with a piece of wood or something so it doesn't come down of your head.
After that it is just a matter of removing ALL of the bolts to get the guard off.
The hardest part is re fitting it and getting the panel gaps right.
coasty
the voices told me to
kanwal nsw
vz equipe & vt berlina both v6
he he he, i took mine to a panel beater. so much easier. must be getting lazy
