As the title states... I just got it and I don't wanna "force" it, knowing me i'd brake it I am gonna to replace the stock rear speakers thanks in advance Xalies
1. Remove rear seat 2. Remove both seat belts where attached to rear quarter 3. Remove rear quarter side plastic moulds 4. Remove rear middle brake light 5. Remove 3 plastic lugs in parcel shelf 6. Lift parcel shelf and remove
hi i'm not sure if you've done it or not but: 1. take the bottom seat off by putting hand in between seat and lifting up and back. 2. the back of the seat have a bolt each holding them in. take them off.and they just slide up. 3. leave the mdidle seat there and just fold down or take the four bolts off whatever easier. 4. don't worry bout seat belts. 5. parcel shelf will slide out past them. 6. pop out the three lugs on the top and the three lugs on the front. 7. then unscrew tail light and bracket 8. now just lift out at an angle. 9. be careful when installing speakers. 10. are the 6 * 9 ? 11. if so be careful you might want to make up brackets to screw threw underneath because the parcel shelf will break away if you arent' careful. 12. be sure not to put speakers too far back on the parsel shelf make sure they are in the middle if possible. this might not be any use for you. but i just did it to my car. you might have already done it by now. cheers
