How to remove rear wall behind seats in VF ute?
BillEnglish
19
Mudgee
2015 VF SV6 Ute
Hi all. I want to put a speaker behind each seat on the back wall of my ute and wanted to know how to do this?
RevNev
VF II SSV Redline Ute
The rear panel on a ute is a mongrel to remove. I put speakers in the side panel, much easier!
vywgn
1967 Holden HR Premier Wagon / 2015 VFII SV6 Sedan
In the side was the factory location if it had them
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
The rear wall is one piece from B pillar to B pillar.
Might be easier to remove the seats.
RevNev
Yes, and the console and battery. There's 2 screws at the bottom your hand can't reach to refit and takes a couple of goes at super gluing the screw to a long shank screwdriver to align them.
lmoengnr
Donating Member
Sunbury Vic.
What’s the easiest way to remove that side panel?
There is no easy way, the 2 side panels and rear panel is one piece.
Disconnect the battery, remove the seats, remove the trim panels that secure everything around the rear wall...
Good luck.
