how to remove the back quarter exterior mould in VY sedan ?
TheIceman
VY Ex-cop
trying to get this off and dont want to break it, how do they come off? not actual picture just one i got off internet, same thing.
TheIceman
VY Ex-cop
surely someone must know
ant797
bunbury
vy s
i dont know but its either clipped on or its got that black foam glue strip can only sujest to try pry it gently from underneath from one side see if it comes out a little then move up a bit try pry a bit more little at a time
crew chief
WK LS1 Turbo, WB Ute, VF 2300 Harrop
Urethane holds them on, used to destroy them to get them off in the plant then just fit a new one. Does it have to be removed?
TheIceman
VY Ex-cop
thought it may be something like that. i will leave it on and paint over it.
TheIceman
VY Ex-cop
i had a look at it again, found my long skinny screw driver and gently pried them off. they both came off in one piece without damage, slight bend to them afterwards but easily bent back into the correct shape and fit back perfectly.
they are glued on with black polyurethane with 2 locating pins.
they are not plastic they are alloy as well. i always thought they were plastic.
