how to remove
figjamidhVK8t4
39
84 VK 3.3 Converted to EFI
hey i stripping black 3.3 block i was wondering if some1 could tell me how to remove this pully cheers.....
craigvk
Banned
VK 5L Calais
Hard to figure out what is in the photo, but you'll probably need access to a bearing puller. Wasn't there a nut on the end of it? What pulley is it?
craigvk
Banned
VK 5L Calais
Find a mechanic with the tool and give them a six pack as thanks. :)
figjamidhVK8t4
39
its what the big bottom pully bolts onto....
Goon
Scientific Tuning
BrisVegas. QLD
VY CUSTOM.
You dont have a greg's book ? :p
Then buy one!
There chip as chips over ebay, i brought mine for 15 dollars!! almost new !
Sorry mate ive seen u ask a few question which i wish i hada book to give to you, it would make it so much easier :D
figjamidhVK8t4
39
I HAVE 2 gregs and the black calais 1 i must be blind as a bat i spent ages seaching through both so i geuss the search is on again...
vkberlina
VK Madman
44
NSW Central Coast
www.members.westnet.com.au
Ok its the harmonic balencer your talking about, you need a harmonic balencer pully to get it off the end of the crank shaft.
They are a friction fit, spray a pit of inox in the centre the day before you try pulling it off it will help it come off more easy.
cheers
Scott
GreenGremlin
www.brockcommodores.com
VK Calais
get a gear/balancer puller, about $15 from supercheap, you place the three bolts in the three threaded holes in the balancer pulley and the threaded centre bolt that locates into the centre of the pulley needs to be tightened to pull the balancer off...
if you had trouble workin that out, wait till you get to the two philips head screws that hold the cam retaining plate in, you'll need an impact driver to remove them, if you snap em then it'll be fun and games with a bolt extractor. I recommend getting a can of liquid spanner and give them a squirt every 4-5 hours and another squirt before leaving it overnight before any attempt at removing them.
as for the rest of it, just follow your nose, oil pump + dizzy have to come off and lifters removed before you can slide the cam out... good luck, theyre a good motor to learn on....
synoptica
Stripping VK - PM me!
40
SE Suburbs, VIC
No longer a Commodore
I can't believe it took 8 posts before someone was even able to identify it as a harmonic balancer!
This is a worry :|
