[NZ] How to replace key with broken ignition
Dieselsniffer
New Zealand
Vx acclaim
Hey not sure if this is the right thread but need some help, my ignition recently carked it so a mate got a mate to pull it for me but he ended up breaking the casing even more making it so I would have to replace more than just the barrel, this worked fine as I could just unlock with the key fob to disable immobiliser, then use a good ol screwdriver but I got the key wet and it won’t work now, how can I map a new key fob without the ignition barrel?
slipknot09
Donating Member
41
Melb
VY Calais
Do you still have the slipring? The part around the barrel the key contacts when inserted. If not maybe get one
Dieselsniffer
New Zealand
Vx acclaim
I did, I must’ve misplaced it, do u think if I just got it all connected and held the metal part of the fob up against it it’d work?
slipknot09
Donating Member
41
Melb
VY Calais
Yeah I do, you will need to somehow connect both sides of the circuit tho. But yeah I don’t see why it wouldn’t work
slipknot09
Donating Member
41
Melb
VY Calais
yes it is, that could be worked around tho, use your knife, jam a wire in or find the right terminal that is normally on the back of the barrel
Dieselsniffer
New Zealand
Vx acclaim
This is what I’m working with haven’t been able to get it to work yet, any idea where exactly I should be trying
Dieselsniffer
New Zealand
Vx acclaim
nvm my photos won’t go through
