how to replace rear side window in cargo bay on a vt wagon
myvtwagon
nelson bay nsw
vt exec
Hi All,
You may have seen on other posts i have smashed my rear lhs window in the cargo bay of my vt, (as you look from back of car), i was wondering if anyone has any pointers as to how to change the glass my self, im very handy but im wondering if i should bother atall any ideas would be a great help cheers guys Tim....
keza87
JCCC NSW Member
VX/VY/VZ Wagon LS1
I had a quick look at mine last week and believe it is just as easy as a VN-VS.
What you need to do it take the interior plastic off surrounding the window then undo the 10mm plastic nuts that hold the window in place.
When putting the new window in use some windscreen sealant from any auto place to help seal it. The original sealant used by holden is just foam and starts to leak after some time. You will also require some metholated spirits to clean the surface for a better seal with the sealant.
It is very easy to do.
myvtwagon
nelson bay nsw
vt exec
thank you very much sounds doable ill attack it tommoz when my hangover clears out lol
