Hellforleather
- Oct 6, 2018
- 1
- 1
- 1
- Age
- 54
- Location
- Abermain
- Ve s2 sv6
Why take the pics down?..... as the old saying goes, a pic is worth a thousand words
They were probably hosted by Photobucket, and the OP probably didn't want to pay the extortionate fees.Why take the pics down?..... as the old saying goes, a pic is worth a thousand words
Hey mate, I dont suppose there is any chance of you posting the pictures again. I have had the same thing happen to me and need to change the drivers side quarter panel.Hello everyone,
I have replaced my front drivers quarter panel due to some inconsiderate prick doing a hit and run on it, so during the process of replacing it I took pictures to show how it is done.
To do this job the car must be jacked up on the side you will be working on, I strongly suggest using pin stands for your protection against falls and to also chock the back wheels.
For this job you will need a phillips head & flat head screw driver and a 10mm socket/ratchet with an extension bar (around 300mm) as all bolt heads are 10mm, and possibly a pair of pin nose pliers if the plugs are hard to get out.
Firstly undo the 2 screws connecting the splash guard and the bottom trim to the quarter panel
Next you will need to undo/release the clips holding the bottom trim on, be gentle and don't twist or pull to hard or the plastic clips will snap from behind, wiggle and pry forward one section at a time gently, you'll only need 3-4 of them from the front loose as a little twisting/pulling is required to undo the bottom of the panel
Next undo the 2 bolts holding the bottom of the panel, in this pic you can see the plastic clip (which is broken off the plastic plug behind..try not to do what I did) which holds the bottom trim on
Next take all the plastic plugs out of the inside splash guard by removing the middle out of the plug 1st with a flat head screw driver, don't forget the 2 plugs under the car holding the splash guard on
Once the splash guard is out it will become clear what bolts and screws need to be removed, there are two visible bolts and one hidden bolt/screw at the front connected to the bumper
Pop the bonnet (if you haven't already) and undo the 2 bolts holding the top of the guard to the engine bay
Next open the car door and undo the screw followed by the bolt underneath
In this next image you will see that I have disconnected the indicator wire (which was done before completely removing the panel) also you will notice a bolt hole in the center next to the door, this bolt needs to be removed with an extension bar connected before the panel can be removed, to access this bolt you come from the wheel arch and take out the padding inside which has a little black foam block glued to it, just pull it out and you will see the bolt that needs to be taken out
Now be very careful getting the panel off as I scratched my door a little doing this, start taking it off from the front light and bumper then from the windscreen area and lift up, before taking it off completely detatch the indicator wire..now it should be removed.
Notes: When it comes to putting the new panel on you will need to loosen and tighten certain bolts to make sure the gaps between the door and the panel, and the bonnet and the panel are even also you need to transfer the indicator and the threaded sheet metal tags around the holes to the new panel.
Extra pics:
Damaged guard off
Indicator fitted to the new guard
Edit: Pictures added and resized
Hope this helped.
Hi @AlzVS97 great write up! I'm having trouble viewing the images, any way of sending them to me? I want to change my guard this weekend and the pics would be great as they would save me time and frustration. CheersHello everyone,
Extra pics:
Damaged guard off
Hope this helped.
