Well my car is going like a rocket after the knock sensor codes are gone. Yea accentstencil there are two types of fuse boxes used in this generation. You have the older model, but they are pretty much the same. Yea it is that fuse "Eng cont bcm", it controls the power into the ecu. When you pull that off, the ecu has a huge capacitor which you have to discharge. Thats why removing the battery does not work, because the ecu is still charged up by the capacitor. You have two choices. First of all the temperature has to be above 80C (fully warmed up is 92C). You can either remove the fuse with the car off, and then leave the ignition on for the capacitor to discharge (You will hear a beep from the dash when it is discharged). OR you can do it my way of pulling the fuse while the car is running, my method is a little risky but will immediately discharge the capacitor. Your choice. Don't forget to warm the car up. This will reset the ECU and all the codes once the power runs out and after you reinsert the fuse. I have run my car for two hours and now I am only getting the oil sensor code, all the other codes are gone!
