i assume the same was as the vn? but considering the vp ones moulded to the window you have to remove it in 1 go, they'res 3 plastic nuts behind the plastic panel in the back and then 3x screws and thats all that holds it in
That bit is a piece that hides the join where the 2 panels meet. It has 2 pins cast into that covering piece that sits in holes in the car...problem is that they are glued into the holes with poly urethane....so you slide something narrow in behind it and SLOWLY work the pins out of the holes... dont be tempted to grab it by the ends and violently pull on it because it will break,
