how to take out the top bit of your dash???
adamrollo9
2008 HSV Clubsport
g-day guys i would like to know how to take out the tap dash so i can replace as current one as a crack through it?
greenacc
Searching for the billion
VE Berlina
which bit you mean ? the panel around the speedo that goes across to the AC and hazard switches ?
adamrollo9
2008 HSV Clubsport
nah the top part where you put the dash mat along
keza87
JCCC NSW Member
34
VX/VY/VZ Wagon LS1
That would be the complete dash!
If you know what you're doing you could do it in about 2-3 hours.
It requires taking the lower half of the dash out like the glove-box and the plastic around the radio.
Then take the demister vents out at the base of the window (2 screws) This will show you all the screws that hold the dash in. Then where the side vents go to the door there is a screw on each side.
You will also have to dis-connect the dash loom.
Re-installation is the reversal.
