how to tell the differance
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Greggles_VS, Sep 26, 2012.
  1. Greggles_VS
    Greggles_VS The Noob
    VS Acclaim V6 Ecotec
    Going to the local wreckers today to look for parts, how would i tell the diff between my std rockers and a set of upgraded roller rockers? Will the ratio and brand be stamped in them or how do i tell? Cheers
  2. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    Proper roller rockers will have a roller at the tip of the rocker where it pushes down on the valve. The standard rockers, and some of the cheap ass "so-called" roller rockers dont have the roller tip on them. (proper roller rockers such as yella terra will have roller tip as well as needle roller bearings in the fulcrum.)
  3. Greggles_VS
    Sweet just googled images n seen the diff. If i pull out the roller rockers, is there anything else i should pull at the same time that i will need?
  4. The1
    The1 A Memcal a Day Keeps..
    QLD
    VS V6 Berlina Auto
    if your just swapping rockers over it should be fine, it is highly advised you get new bolts as the stock ones are single use TTY
  5. Greggles_VS
    Aight sweet, sucks cos i couldnt find any :( hard to find many 6's with roller rockers in wreckers :(. Can i get them from an 8 or diff setup?
  6. wraith
    Demonicaland
    VX V6 Berlina. 2003 VW Passat
    Just standard ratio roller rockers won't make much difference. Your chance of finding some are pretty slim.
