How to you change gearbox oil?
SMIT
Donating Member
35
Mornington Peninsula, Victoria
VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
hey i have a VT S 5 Speed Manual (Getrag im preety sure, altough the guy who i bought it off said it had a VX GTS one in it????) anyway how do you change the oil in it, i have no idea when it comes to this stuff.
Feedback much appreciated.
SweetWagon
booosted
34
Springwood NSW
VS Berlina Wagon Supercharged
I would suggest to you investing in a gregory's manual for your car, they're very handy. but anyway get underneath the car, the should be a drain plug and a fill plug. You need to drain out the old oil, and place the recommended amount of the new oil back in. It's fairly straightforward.
glen_56
vt in progress
You will need a 17mm Allen key for both plugs.
The drain plug is underneath.
To fill it back up there is another plug on the drivers side. Put oil in until its level with the bottom of the filler hole.
vxexec350
Adelaide Northern Suburbs
VZ SS Thunder/VX Exec LS1/VN Berlina 5.0
BTW The VX GTS has a 6 speed. I wonder how many other fibs the guy you baught it off told you.
Why do you want to change the gearbox oil? It isn't a usual service procedure. It is usually only done after major work is done to your gearbox.
Pete
beeks
Banned
N.S.W
XR6 5sp MKII + DR 600S
Pete
Indeed, it pays to have some knowledge and do a bit of research before purchasing a car.Sounds like the guy could have told you it's a V8 and you would be none the wiser.As suggested, buy a manual, you'll find it will pay for itself over time.
bradcad
VT Berlina & mazda 2 DE
unless you get the oils tested you can't change them often enough
the small cars i've owned all copped a dead set flogging. After 40 000k's the box would start to get notchey. An oil change to quality stuff would clean her right up
keep in mind manufacturers such as Daewoo actually specify the gearbox oil should never be changed.
Not such a bad thing to have your gearbox oil tested or just change it every major service (40 000k's) as its not a hard operation.
SMIT
Donating Member
35
vxexec350 said:
BTW The VX GTS has a 6 speed. I wonder how many other fibs the guy you baught it off told you.Pete
Yeah i thought as much, but nothing i can do now. The RACV said there was an excessive leak on the gearbox joint (???) anyway, now the gearbox is stuffed some people said it might just need an oil change but i dont know.
SMIT
Donating Member
35
Not knowing a a VX GTS has a 6 speed, there is no way i could have known, but i kno an 8 wen i see one.
bradcad
make sure you use the best oil you can find, and dont use additives....did they mean the rear seal is leaking?
