vsiicalais
Donating Member
- Aug 23, 2007
- 295
- 11
- 18
- Location
- Wonthaggi
- MY15 VF SV6 Storm
How To - VT Brake Upgrade
N.B. I take NO RESPONSIBILITY for damage done to your vehicle if you follow this guide and it does not work, I didnt have a problem tho!
Tools and Parts Required
(pic 1)
Instructions:
1. Make sure you have all the tools and parts you are going to require for this job.
2. Loosen the wheel nuts slightly
3. Jack the car up and support of jack stands.
4. Remove the wheel (pic 2)
5. Remove the two bolts from the rear of the caliper (pic 3)
6. Clamp the brake line near the body of the vehicle to reduce fluid loss (pic 4)
7. Loosen the bleeder on the rear of the caliper enough to allow fluid to come out. (pic 5)
8. Twist the brake line about 90 degrees and push towards the engine bay to remove (pic 6)
9. Remove the caliper from the disc (pic 7)
10. Grab the new brake line and clamp that one as well (pic 8)
11. Undo the existing brake line from the vehicle and remove (pic 9)
12. Replace the brake line with the new one and place it back in the clip on the strut (pic 10)
13. Remove the old disc from the vehicle (this may take a while and may require a rubber mallet or a hammer if you are disposing of the old discs) (pic 11)
14. Remove the guard from behind the hub as the VT caliper will not fit with it still in place (you could replace this but I will do so later on) (pic 12)
15. Place new disc on to the hub and push it on as far as you can. (pic 13)
16. Place new pads into the VT caliper ensuring the pistons are fully retracted. (pic 14)
17. Fit the VT caliper to the disc make sure the bleed nipple is at the top and ensure you tighten the two bolts on the back (pic 15)
18. Fit the brake line onto the caliper and tighten (pic 16)
19. Undo the bleeder and remove the brake line clamp to allow fluid to come through. (pic 17)
20. Bleed the entire brake system ensuring the reservour is kept full.
21. Replace the wheel and place vehicle back onto the ground
22. Enjoy the new stopping power!
(pic 1)
Instructions:
