Hq 5.0 firing problem
hq-racing
HSVR-28
S.A
VT L67 DAILY, WORKED VR CLUBSPORT WAGON PROJECT
hey, ive got a problem with my hq 5.0.
ive resently changed motors in hy hq and now it wont run..
this motor came out of running car and now its in mine its not firing right..
ive changed leads, plugs, coil, dissy cap, done the points and condenser and cap, checked the timming and its still running on 4..
what could it possibly be?
could it be the dissy isnt working?
any ideas would be great...
thanks
tom
:hit:
Ado
Are we there yet?
35
vsII statesman L67
Was the dizzy in the motor when you fitted it?Might have knocked it.
Dayvo
Because i can
64
South East,Victoria
VE SV6 Series 2
Did you replace the leads in the right order?
Calaber
Nil Bastardo Carborundum
Lower Hunter Region NSW
CG Captiva 5 Series 2
+1 for Dayvo's suggestion. Incorrectly installed leads would be my first port of call. Two things to consider here. Correct firing order when installing the leads into the distributor cap and correct direction of rotation.
hq-racing
HSVR-28
S.A
yea i done the lead rotation by the book..
correct if wrong..
1 2 7 8 4 5 6 3
all done clockwise from number 1 on the dissy..
and yes the dissy was in the motor when changed over, but has been tacken out and put back in to check it was in the right place..
another question, i wasent sure but i noticed the dissy condenser (capacitor)low tension lead was on the negitive on the coil?
is that right?
thanks for the help guys..
VrWagz1
The Wagon on Wheels..
wollongong
www.wagzhome.justcommodores.com.au
VE SSV MY09 Auto Wagon
Q. how do you know its only firing on four cylinders.
It might be the injectors possibly. The dissy isnt in a tooth out possibly.
Ado
Are we there yet?
35
vsII statesman L67
It has points so id say its a 308 with carby
hq-racing
HSVR-28
S.A
hey, ive had a look at the firing order and my number 1 is were ur number 4 is but when i did it i checked cyl 1 was up when i did it.
i checked to see it was running on 4 by running water over the cyls to see which 1's were hot..
only 4 were..
i rekon it could be the dissy..
im gonna get another mechanic down here to get another opinion, if all else fails idz just get another dissy..
thanks for the help guys!!!
slowly narrowing it down!!
