Hsv ap racing brakes on ve
bblatch05
brisbane
2010 VE SS
Hi all I picked up front and rear HSV AP racing calipers to go on my VE SS. I have read on here the brembos need new bolts but can't find anything regarding the bolts for the AP Racing calipers. Do I need new bolts front and rear and if so are they the same as the brembo bolts.
Got a great deal $900 for front and rear calipers discs and pads so keen to get these on my car
Thanks
Smitty
Moderator
Bayside Melbourne
GenF SV340 R8 Tourer, VK race car, ZX12R
.. different bolts to std or factory Brembos
and I know you can buy the HSV front caliper bolts from your Holden dealer
( I got a set when I pulled the calipers off to replace the front rotors.. they are one use bolts)
rears..? no idea
bblatch05
brisbane
2010 VE SS
Ok thanks will go to holden today and get new front bolts and enquire about the rears
Xplaya
NZ
HSV
Did you find out about the rears needing them?
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
All the caliper mount bolts are supposed to be 'single use', as they're "micro encapsulated".
Loctite also works...
bblatch05
brisbane
2010 VE SS
i went to 1 Holden dealership and was told all HSV parts go through Zuppps mt gravatt holden dealership and was told they use the same bolts front and back.
Zupps wasn't going to sell me the bolts as i didn't have a HSV VIN but as i knew him he sold me 4 as that was all the stock in QLD.
he advised to either go to AP racing or an industrial bolt supplier to get them. bolts required are M12 x 1.5 x 45mm flared hex head high tensile 10.9 grade. these will need red loctite from what i could find online the Holden ve ss caliper bolts are same size and pitch but 5 mm shorter but have read a few sites online say that they still fit. part no is HSV 73A-100604
going to try to get the 4 for the rear tomorrow just in case.
MrBags
45
VE SSV Z SERIES
So the rear AP Calipers use the same bolts as the front, good to know.
bblatch05
brisbane
2010 VE SS
I can confirm the bolts from as stock calipers defiantly are the same size as the bolts from HSV.
Fitted my new calipers today using the same bolts
Xplaya
NZ
HSV
lmoengnr
Donating Member
Sunbury Vic.
So they are not single use bolts? You can re-use them? Or was there a special way to take them off and re-use
Loctite for the win!
