HSV Gauge control unit.
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Kalle, Mar 10, 2020.
  1. Kalle
    Kalle New Member
    Denmark
    Pontiac G8 GT
    Hi,
    Does any of you have a eeprom dump of the High Range ( E2 ) control unit ( VDO Blackbox??
    I have an 1. gen Blackbox ( low range ) and have copied the eeprom data from it - my task would be to try reprogram it and put a set of High range gauges on to see if this would work....but need a copy of the eeprom data from the newer Blackbox.
    Eeprom is a ST95320 and is located right beside the yellow connector.
    Regards Kasper
  2. 07GTS
    07GTS Well-Known Member
    Australia
    VEGTS BLOWN E85
    ive had mine done by vdo here so it should work, the data is not possible to get as its locked by HSV so unfortunately i cant help there as i dont have the ability to read it myself
  3. Kalle
    Kalle New Member
    Denmark
    Pontiac G8 GT
    Hi 07GTS,
    Thanks for the info - I'll try and give them a call. The program itself to program these units costs a staggering 3000 US$ made by Siemens for there CANcockpit series ( same as used in Commodore VE HSV cars ).
    But the eeprom shuld be able to read - HSV cannot lock that ;o)
    Regards Kasper
  4. Kalle
    Kalle New Member
    Denmark
    Pontiac G8 GT
    Hmm, easyer said that done - no one in Denmark can program these VDO CANcockpit units ;o(.
    If anyone did have a copy of the Eeprom I'd love to have a copy of it ;o))
    Regards Kasper
