All that being said, I also got the HSV headers supplied & fitted for next to nothing, so it was a no brainer for me.
And that seems to be the deciding factor. Cost. Doing an upgrade with less effective parts because they are cheap is a false economy. Sure, they are probably better than the stock items, but the gain you get over stock items, is it really worth the time and effort to do?
Spending the money on true performance upgrades and getting the full benefit from the upgrade has to be worth more in the end than just replacing a part with one that is marginally better.
An example of the above line of thinking is my V8 Range Rover. There are extractors available for it, I contemplated fitting a set for performance. But on looking at the original manifolds and engine pipes, the gain from extractors is not really worth the effort. The original manifolds work quite well, and with the engine pipes on, they are pretty close to the 4-2-1 that the extractors would be anyway.
The same can be said for the HSV headers over the standard manifolds, yes, they are better, but only marginally. It's not really worth the effort ti fit them for the little performance gain you get.
On the other hand, if you weren't in a postition to be able to buy proper aftermarket extractors, then they are still better than stock.
