delcowizzid
on holiday
yip correct shimming is important.youde be lucky to get away with using stock shims when fitting the spool every diff centre needs different shim thickness least youll get some power back.think of it as a horsepower upgrade
I used the stock shims because every how-to I had found of fitting a spool yourself just stated to re-use them, since it was the same centre going back in, just different internally.
An outer bearing race swap is entirely possible actually. I didn't know they had to stay on the same sides
exactly! and it's shiny as well, now!at least you come away with some more knowledge and a fresh diff :thumbsup:
