humming noise
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by freshh, Aug 19, 2008.
  1. freshh
    freshh STAUNCH
    Melburn
    please help
    gday i own a 96 vs ute 3.8 auto.
    when in the car and you have the music low or off i can hear like a slight high pitched humming noise that sounds like its from under the seats.
    it makes the noise my fuel pump made in my vn wagon when i used to turn it on but its constant.
    any idea what it may be and how to fix it??
    cheers johnno
  2. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Maybe it is the fuel pump - try running the engine and have an assistant pull the fuel pump fuse and see if the hum stops immediately the fuse is pulled.
  3. freshh
    freshh STAUNCH
    Melburn
    ok i cant do it right this moment cause my car is over the road a 5 min walk from my house cause there was no parks here, if it is my fuel pump what should i do? would it be a problem?
  4. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    If it is your fuel pump making the noise it may be due to one of the pipes fouling with the body which can make it sound loud. It normally will make a noise but usually only a barely audible hum. The can get noisy when on their last legs. Mine got noisy about a year ago for a few days and then went back to normal but maybe I was lucky....hope yours is the same. When they fail it is usually when trying to start the car - you can get them going again (temporarily) by thumping the bottom of the tank to jolt the pump. Good Luck.
