VEdriver59
- Feb 22, 2013
- 107
- 4
- 18
- Location
- Perth
- VE, 09 of 2008, Omega, Auto, 3.6 Litre, 6 Cylinder
I'm going to change the plugs on my ve because its done 135k without the plugs ever having being changed, to the best of my knowledge anyway.
As this car goes through humungas amounts of fuel I am wondering wat the problem could be if changing the plugs does not fix the problem.
One thing I've noticed for a while is that it seems to idle fairly fast, eg, I have to keep my foot on the brake as I go into the garage so as to stop it from hitting the wall. Once upon a time it would roll into the garage and only a slight touch of the brake would be enough to stop it without any jerk.
What causes it to idle too fast and would that explain the amount of fuel it slurps up?
If changing the plugs and reducing the idle speed does not stop the excessive ful use what else should I look at?
There is no smell of petrol anywhere so I cant see that there is a leak in the system but there must be something causing it.
If petrol was alcohol, my car's engine would get locked up for 2 years.
thanks
thanks
