Wheatley098
- Oct 6, 2012
- 318
- 1
- 18
- Age
- 30
- Location
- Australia
- Commodore VE SSV Ute
Good afternoon all
Commodore VE SSV 2009 Ute
First off I know this has been posted twice but I believe my issue is different somehow
I started off with having an actuator fault because my car would stay on "Face" when I selected "Feet" so I knew one if them was at fault
Upon changing over the actuator on the lower passenger side (Hot/Cold) that's when my real issues started
So when I run the re-learn process by holding down the rear demister button for 5 seconds the actuator that I replaced rotates all the way down to the HOT position but does not come back up and stays stuck there but when I take the actuator out and let it freely hang the cog moves in both directions as it should do normally and I wonder why it is doing that?
Someone mentioned to me it could be my recirc actuator so I replaced that and ran the re-learn again and the recirc moved back and forth as normal so that's fine
I am still yet to identify the real root cause of this problem hence why I am about to rip everything out and make my car go back to a single zone if that's even possible
