Mick rooster
- Jan 30, 2019
- 30
- 0
- 6
- Location
- Wakeley
- Holden commodore
Are vr vs and VN starter motors the same on V6
i tried all three wreckers in Launceston and no one had a shim. Thanks for the heads up i will try an engine builder.TBH, I'm wondering if there is a difference between the older V6 and newer V6 starter motors. Maybe a you need a late model one to match the style of bellhousing for the transmission? For some reason I keep remembering someone modified their starter to make it fit when doing a trans swap but I just can't quiet remember what or where it was. Might need to track down some pictures of the later style starter motors and see if they are greatly different around the throw out extension housing.
Really? I'd say a decent performance shop should stock various shims as a lot of aftermarket style starters need them to make them fit properly. Or go to the wreckers and pull one out of a Commodore there.
only difference is auto or manual for a v6
I honestly think that not all Buicks came out with shims, one because, one wrecker said he has never seen one and two they had 30 starter motors on the shelf but no shims.
nah it only makes this weird type of running on noise, like its not stopping straight away in the winter. Couple of members said to try fitting a shim. Weird that it only does it in sub zero temps.Bugger for you. It can't be to bad.
does sound like it could be throwing out to far!Not really, when things are really cold clearances tighten up ever so much.
