I changed my auto transmission and the starter motor sounds like it's hitting the flex plate
vs-lover
VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
Must admit that I've never fallen across any shims. I think you'll find that a shim would've only been supplied with certain brand of starter motor that were sourced outside the normal Bosch line up. There were a few changes along the line with the body diameter as the earlier ones were fatter while the later ones became somewhat slimmer. BTW I recently pulled a starter off a VT and it went straight into my Brother in laws Series 1 VS without any issue whatsoever. Both units were Bosch made.
Immortality
Staff member
Sth Auck, NZ
I think it's mostly the Manual trans that had shims with the starter motors. I've seen a few but then I've had a few manual cars.... I probably have some old ones in the garage too.
Mick rooster
Wakeley
Holden commodore
I have tried putting washers in between where the shim would be made no difference
Immortality
Staff member
Sth Auck, NZ
To quote myself...
Thinking logically about this, you are using your original starter with the original flex plate on the same motor. As long as you have put it all back together as it came apart there is not reason for the starter pinion to hit the flex plate. If that is the case it might be the starter housing is getting some interference on the new bellhousing. pull the starter out and look for some new shiny witness marks. A touch up with a file might be all that is required.
gohrdrgomad
Australia
VxCaly57
Automatic
wtf? Me speaking to someone else about someone else...lm not quotin hear but immortality did suggest to check the starter to ringear before the trans fitment to be certain no cracked eggs "Rooster" amongst all the confusion..
Mick rooster
Wakeley
Holden commodore
Its hot here to sorry to disturb your concentration hero
