I changed my auto transmission and the starter motor sounds like it's hitting the flex plate
Mick rooster
Wakeley
Holden commodore
I know what's wrong and my mechanic worked it out no one here
Mick rooster
Wakeley
Holden commodore
Dumb arse me didn't undo the torque convertor and just thought I could slip it in my mechanic said you got more chance of winning the lottery now I have to pull it all apart again what a goose he said because it's not in the shaft properly it's hitting the ring gear
Mick rooster
Wakeley
Holden commodore
What a dead set goose now I have to start again lol at my stupid mistake
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
Hope you haven't f__ked the auto pump?
gohrdrgomad
Australia
VxCaly57
Other than providing some informative information
so you didnt engage the tourq converter onto the transmission before bolting to the flex plate and bolted it all together. Well thats a hole new chook shed rooster.
losh1971
North Tas
VE Series I SS Ute
Been there done that. You should fit a new seal as when you don't slip the converter into the trans first before bolting it up, the seal often ends up damaged.
losh1971
North Tas
VE Series I SS Ute
The front seal. Check the trans as well for damage as bolting it without the converter pushed in to the trans can damage things as i found out the hard way.
