I changed my auto transmission and the starter motor sounds like it's hitting the flex plate
Mick rooster
Wakeley
Holden commodore
What I cannot understand is I drove it like that how can that be
gohrdrgomad
Australia
VxCaly57
Been there done that. You should fit a new seal as when you don't slip the converter into the trans first before bolting it up, the seal often ends up damaged.
Hey loshy, how com you didnt jump in and tell rooster how not to do it earlier, l thought he said he had starter moter issues.
Mick rooster
Wakeley
Holden commodore
I'm dreading doing it all over again after four days of pulling my hair out trying to work it out I have two other boxes here anyway might just chuck one of the others in less hassle
Mick rooster
Wakeley
Holden commodore
The front seal. Check the trans as well for damage as bolting it without the converter pushed in to the trans can damage things as i found out the hard way.
Can I ask you a couple of questions loshy
Mick rooster
Wakeley
Holden commodore
When I undo the torque convertor and slip it on the box and put it in how do you turn the ring gear to do the torque convertor back up
Immortality
Staff member
Sth Auck, NZ
I'd suggest buying a copy of an automotive repair manual of what ever flavour you prefer.
Mick rooster
Wakeley
Holden commodore
I don't need a manual I just done one thing wrong and loshy can probably answer that question by the sound of it
Immortality
Staff member
Sth Auck, NZ
Ok, if you say so.
