I have a VX SS Commodore which has the srs light showing on start up and message showing a fault
Robbie S
VX. SS Commodore
I have taken the vehicle to a mechanic who has put a scanner to check the fault codes but it shows nothing but says cannot communicate with the system. Any ideas what the problem is. Mechanic could not advise me what might be at fault
BlackVXGTS
Melbourne, SE
You need to find someone who has a Tech2, Tech2 Clone, or equivalent scan tool, to display the fault codes.
oska
vx custom 600RR
unplug your ABS module if the fault goes away then that's the problem .... very common
BTW that's not a VX cluster
Robbie S
VX. SS Commodore
The scan tool has been used but no fault codes come up and it can't find the module
Robbie S
VX. SS Commodore
I presume its the unit under the centre console
Robbie S
VX. SS Commodore
Sorry.
Its a VY built Nov 2002
oska
vx custom 600RR
it's in the engine bay attached to the front of brake modulator (the silver box with the pipes)
pull the red tab and it releases the connector
Robbie S
VX. SS Commodore
Have tried removing the cable to no effect. Airbag fault is still showing. Any other ideas
Thanks
EYY
VS Statesman
Abs module (in engine bay as pictured) or airbag module (under centre console) if it won’t communicate at all. To replace airbag module isn’t difficult, but will need one with the same number if airbags and pretensioners (e.g. 3 loop, 6 loop etc).
Abs module is a little more involved though and you need the exact part number otherwise you’ll have issues with faults, traction control, abs and airbag etc.
