If you look at the manual it will give you instructions on how to custom set the climate control to your individual requirements when a certain fob is used to start the ignition (you should have two). From your query it appears that A/C is pre-set to turn on when the engine is started. Climate control works correctly with air con activated otherwise, it doesn't work as expected.
