I need help
Discussion in 'VE Holden Commodore (2006 - 2013)' started by huthy14, May 6, 2013.
  1. huthy14
    huthy14 New Member
    Canberra Act
    ve ss
    I need help, I'm installing hsv ve gauges and I can't seem to get the lights to turn off. Going by car modded tap into the body module but I can't do that. It's too hard basket. Is there a easier way?
  2. MYVESSV8
    MYVESSV8 Well-Known Member
    Brisbane/GoldCoast
    VE 6LT M6
    what are you looking for, power, light, ground etc
  3. glennho
    glennho Member
    PERTH ,Darch WA
    2006 VE SS
    use the smokers pack plug behind the console on the right hand side below the stereo head unit for power,lights etc.
  4. MYVESSV8
    Brisbane/GoldCoast
    VE 6LT M6
    as glenho says thats where i've got mine from as well (hows it going, managed to get some red leds for mine instead of lamps) we've both done this mod lol
  5. huthy14
    huthy14 New Member
    Canberra Act
    ve ss
    Ok this is what I did. http://www.carmodder.com/view_doc.php?doc_id=59&model_id=19
  6. huthy14
    huthy14 New Member
    Canberra Act
    ve ss
    Illumination wire I connected it to body module pin 24 brown plug.
    When gm LAN + wire is disconnected, the lights for the gauges work like they should on and off etc. but when I connect the gm LAN + wire the lights won't turn off, they stay on even if I turn the headlights off.
  7. huthy14
    huthy14 New Member
    Canberra Act
    ve ss
    Do ur gauges lights turn off like they should?
  8. glennho
    glennho Member
    PERTH ,Darch WA
    2006 VE SS
    yes mate,just run your wire for lights to the plug at the back of console and connect it in and bobs your uncle:)
  9. huthy14
    huthy14 New Member
    Canberra Act
    ve ss
    Back of the console where abouts. My lights turn on even without the illumination wire connected
  10. glennho
    glennho Member
    PERTH ,Darch WA
    2006 VE SS
    Bottom right hand side under head unit.youll see the white plug.thats for the smokers pack.sounds like your gauges are getting a 12v+constant power source from some where else.
  11. huthy14
    huthy14 New Member
    Canberra Act
    ve ss
    Ok so I ran 12v ignition wire to power to that white plug u said. Lights work like they should on off etc but if the gm LAN + wire is connected to pin 3 black brown the volts start working but I can't turn the lights off. Lights only turn off when gm LAN + is disconnected. I can turn them off and on etc
  12. glennho
    glennho Member
    PERTH ,Darch WA
    2006 VE SS
    Sorry mate,i really dont know.maybe check your wiring again.
  13. huthy14
    huthy14 New Member
    Canberra Act
    ve ss
    That's okay but can u do me a favor and read that car modded instructions on how to install hsv ve gauges and let me know I that sounds correct
  14. huthy14
    huthy14 New Member
    Canberra Act
    ve ss
    I have checked my wiring and checked it again the only thing I can come up with is that when gm LAN + wire is connect that it's doing two things giving power to lights on the gauges and also making the gauges work. Gm LAN - does the same I just found out
  15. glennho
    glennho Member
    PERTH ,Darch WA
    2006 VE SS
    so youve sorted it?ive only got the twin pod setup which is an easier install.sorry i cant help more.
  16. huthy14
    huthy14 New Member
    Canberra Act
    ve ss
    No I've done something bad. Lost communication with abs control module. Now nothing works. Car says abs fault, ESP off, contact dealer, could this be a fuse? Or have I done something I going to regret
  17. glennho
    glennho Member
    PERTH ,Darch WA
    2006 VE SS
    try disconnecting the battery and reconnect it. this some times resets some faults
  18. huthy14
    huthy14 New Member
    Canberra Act
    ve ss
    All sorted was a fuse. Gave up on the install, I just whacked it all back together, everything is working except I can't turn the lights off. Over it.
  19. huthy14
    huthy14 New Member
    Canberra Act
    ve ss
    So annoyed right now, drive out into the sun and the lights turned off.
  20. Aussie Willy
    Aussie Willy Coal Miner
    Hunter Valley
    VE SSV Redline 2012
    Mate, I feel you, I was reading this and going "WTF". can happen to the best of us.
