I run a fairly high idle on my vr
RorzaaBoy
21
94 vr acclaim wagon
I have my idle set at about 1300 rpm to keep the car running as the alternator **** itself. Just wondering if this is bad. It crawls when i put it into gear.
losh1971
North Tas
VE Series I SS Ute
Well i guess considering you will soon break down because the battery will become too low, that would be bad. Why not just put a 50 buck SH alt on and be done with it?
RorzaaBoy
21
94 vr acclaim wagon
I went to a wrecker and they asked $100 for a sh one... No thanks hah, i charge my battery before every trip and only drive when its urgent. The alternator puts out 11 volts so im going to rebrush it
BlackVXGTS
Melbourne, SE
Try just replacing the voltage regulator. Should only cost around $25 or so, and easy to replace.
woteva
NEED 4 SPEED
Adelaide S.A.
Yes, sounds like the reg is stuffed and needs replacing if the alternator still spins over ok. Only takes a few minutes to replace and does not need the alternator to be removed to swap the regulator/brush assembly.
losh1971
North Tas
VE Series I SS Ute
Ashdown Ingram should have the parts to fix your alt. They also sell A/C parts and might be cheaper than Repco.
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
GPC owns both Ashdown and Repco.
losh1971
North Tas
VE Series I SS Ute
Sabbath'
Redblock Jesus
Ahhh that would be why Repco sell some of same parts Ashdowns do, just more expensive.
Freight + Markup would do that. Cheaper to go direct to the source if possible as you suggested. :)
RorzaaBoy
21
94 vr acclaim wagon
Couldnt find a price on ashdown ingram, but found one for $94 at repco. Is it worth buying a second hand alternator or new regulator?
