I'd love to know where you got this information from, because it would be the only car where this would be the case - wider tyres give a bigger contact patch, therefore better grip, lower profile tyres give more lateral strength, reducing slip - the only advantage to a narrower tyre is reduced rolling resistance, which is only of any real use on an EV. The only advantage to a higher profile is a softer ride at the expense of handling...
Links please. I've driven both the four and six-cylinder engines in both liftback and wagon variants and the six is far more drivable, the fact there's no torque-steer on take-off makes a huge difference.
There's far more complexity in a turbocharged four than there is in a naturally-aspirated six; more wear on the oil, more stress on the engine. The four-pot also requires premium unleaded, which adds up over the life of the vehicle. The AWD isn't overly complex; it uses the Twinster system as used in many other marques and is a simple twin clutch pack arrangement - there's no differential, so it's far less 'complex' than a continuous AWD or Haltech system and has proven to be reliable.
Also, there's a massive difference in dry-handling when cornering and greatly increased safety in the wet.
Buying the base-model in any vehicle opens you up to reduced resale value as you're competing against huge numbers of fleet vehicles - always go for a mid-range model for the lowest losses.
The warranty is the same on both vehicles at five years, so 'complexity' isn't really an issue either way, and the AWD system is used in far more 'performance-oriented' vehicles than the V6 ZB.
Kos, I'd strongly suggest you drive both vehicles back-to-back before making the decision.
Keep in mind that an RS-V only costs around $5k more than an RS and the seats are another step-up in comfort & there's a whole host of extras for the money...
