It is on the throttle body which is where the accelerator cable is connected to. To clean, disconnect the wiring, undo the 2 Torx screws, pull it out and give it a good spray with throttle body cleaner or carby cleaner. They come in spray cans. While you're at it, you might as well clean the throttle body.
don't know if VS throttle body is the same as on my VP/VR but treat the screw mounts for fittings, including IAC, carefully because it is not uncommon for them to seize up and then break through the threads. Maybe a hit of penetrating oil a while before undoing the screw mounts?
Ok cool, am trying to remove throttle body completely for proper clean, will view pic on pc when at home, cheers heaps
Thanks for the picture, finally got on my pc, you said most likely my IAC needs a clean, however the TPS was removed.in an attempt to remove my TB, could i have put the adapter between TPS and TB in incorrectly? And could that be the fault of my poor idle and low revs in D and R? Cheers
I sprayed the sh¡t outta the iac and no diff, however i cant see an oring. Will the oring make a diff, and dilo i need to do any form of reset for the cleaned iac to take effect?
