MAHOOVKV8
- Dec 8, 2008
- 22
- 0
- 0
- Location
- victoria
- VK Calais EFI 6 now vp 5.0l and t700
ITEM: IC@E IGNITION KIT Brand new never fitted to engine. Was going to go straight gas with torque power manifold but went standard efi setup on vp 5.0 instead.
CONDITION: New
PRICE: $800.00 neg
DELIVERY/PICK UP INFORMATION: Pick up preferred, But can post at your cost.
PAYMENT OPTIONS: COD, Direct Deposit.
CONTACT DETAILS: mobile:0412 436 369 or pm me.
OTHER INFO:
The ICE 6800MC ignition kit is a powerful digital ignition system with multiple curves designed for naturally aspirated 8cyl engines.
Features:
* Distributor housing machined from 6061 aircraft grade aluminium.
* Hardened and precision ground 1040 chrome moly shaft.
* High temperature roller bearing and oil impregnated sintered iron bush.
* Triggering via hall effect vane sensor unaffected by dirt, moisture or vibration.
* Distributor gears in hardened spheroidal graphite iron or silicon impregnated bronze.
* HEI style black distributor cap with spark plug wires clamp.
* Improved spark output using 6 AMP primary current combined with long duration spark.
* Multiple sparks at cranking speeds for maximum power at starting.
* 16 electronically pre programmed advance curves to suit all applications.
Advantages:
* More total spark energy than any 6 Series CDI ignition.
* 16 electronic advance curves selectable by push button switch.
* Easy installation - simple wiring instructions and mounting hardware supplied.
Benefits:
* Long duration spark lasts 22 crankshaft degrees to fully ignite mixtures.
* Optimised curve can be chosen for maximum power and no detonation.
* Unmatched 3 year warranty.
Available For:
* All popular 8cyl models.
Note:
* Can be used with either Lightning Coil (Part No:4000) or Lightning Race Series Coil (Part No:4100 - pictured).
* Ideally used with Booster (Part No:2316 or 2216) for maximum performance.
* Kit is supplied with either 8100 Series (large cap) or 8200 Series (small cap) billet distributor including SG Iron gear, 6800MC control box, 4100 Lightning Race Series Coil and ICE 9MM Race 1000 Series leads.
PICTURES:
CONDITION: New
PRICE: $800.00 neg
OTHER INFO:
Features:
Advantages:
Benefits:
Available For:
Note:
PICTURES:
