richardpalinkas
Blown Alloytec
- May 4, 2009
- 2,290
- 16
- 38
- Location
- Gold Coast
- Raptor Impulse VZ SV6
They should operate between 0.1v and 0.9v continuously.
When your mechanic fitted the new IAC, did he measure the distance from the flange or gasket mounting surface of the IAC valve to the tip of the pintle?
If the distance was greater than 28 mm, it has to be reduced before fitting.
According to my book, after fitting the IAC, the engine must be held at around 2500 rpm for 20 seconds to reset the IAC.
The PCM will have to re learn its idle mode.
I can take a certain amount of time before the idle motor re sets for the correct idle speed.
