accentstencil
- Jun 30, 2005
- 8,376
- 586
- 113
- Age
- 71
- Location
- Caboolture South, QLD
- WH II Caprice, 5.7 2018 Equinox LTZ V
Is this really necessary, that's 40 minutes of idling.
IDLE LEARN PROCEDURE
Whenever the PCM or the battery is disconnected or the PCM loses power, the PCM’s learned position of the IAC
valve pintle is lost, resulting in an unstable idle.
Perform the following procedure in order to return the IAC valve pintle to the correct position:
Automatic Transmission
1. Turn OFF the ignition.
2. Restore the PCM battery feed.
3. Turn OFF the A/C controls.
4. Set the park brake and block the drive wheels.
5. Start the engine.
6. Shift the transmission selector to D (drive).
7. Allow the engine to idle for 10 minutes.
8. Turn ON the A/C controls.
9. Allow the engine to idle for 10 minutes.
10. Shift the transmission selector to P (park).
11. Allow the engine to idle for 10 minutes.
12. Turn OFF the A/C controls.
13. Allow the engine to idle for 10 minutes.
14. Turn OFF the engine for 30 seconds.
